Thread: Cylinder compatability
    Jan 2008
    NW Indiana
    92
    Did a search and no answer. I want to know if the 85'-87'+ 250R cylinders are the same and can any of them be bolted onto the bottom end of oppisite years? Like can any of those year cylinders bolt right onto the 86' bottom end?
    Bikes I currently own.....
    84' KXT 250
    01' Honda CR500
    98' Arctic cat ZRT800
    82' Honda atc70
    Utah
    644
    I really shouldn't comment on this cuz I'm not for certain, but I believe that the Trx can bolt onto the '85 and '86 tranny, but you have to run a spacer because the rods are slightly different lengths.
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
    Sep 2005
    Lipetsk, Russia
    2,824
    You do indeed need a special conversion spacer plate, but that's it.
    Nov 2006
    southern oregon
    2,338
    it bolts directly on... you just have to use the correct piston for the rod you are using...
    2-stroke lover
    Jan 2008
    NW Indiana
    92
    Quote Originally Posted by cr480r View Post
    My plan is to buy a cylinder off fleabay, have it sleeved with the 310 kit and then install a 4mm crank. Then have it ported for the dunes.
    84' KXT 250
    01' Honda CR500
    82' Honda atc70
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,246
    ALL TRX AND ATC CYLINDERS ARE THE SAME,,,, they will bolt on any machine any year,,, the differences are in the pistons,,, short rod motors use a different piston than a long rod motor ,,,but they are the same bore size,,, so you can use a 89 cylinder on a 85,, or visa versa ..............
