Results 1 to 12 of 12
Thread: help with ATC 70 PLEASE
    Mar 2008
    florida
    70
    Hello all, new to the forum and my first post. I have an 1985 atc 70 I bought to fix up. It sat for 8 years in a basement before I bought it and know nothing of its history. After cleaning the carb and three pulls it started right up with no smoke. After I found the motor does not smoke I figured its worth putting money into. I bought a carb kit with new jets, needle, slide, float, seat, bowl and pretty much everything except the carb body is new. I also replaced the points and condenser and have it properly set at .012. At the moment the motor starts and idles great, I could not be happier. However once there is a load and in the high rpm's the motor will cut out and die. It sounds like its not getting fuel, so I sprayed starting fluid in the carb when it starts cutting out and it did nothing, so I ruled out the possibility of it being fuel related. I checked the points again and they were spot on. However, since I have adjusted the points so many times I have found that the wider the gap is with the points better it runs, but never can get it to rev full rpm at WOT with out it dieing. I checked the coil with a mulitmeter and it checked out ok. The exhaust is not clogged and the airfilter is new. The valve clearance it correct and I dont know what else to do. This thing is killing me, Im about to give up. Please give me some advice before I take a sledge to it!!!!!!
    NE Arkansas
    2,344
    When it cut out like that, reach down and put the choke 'on' (lever up is 'on', down is 'off'). make sure the air filter is good and clean too. If running the choke on helps, you need to up the main a size or so. Any air leaks around the rubber boot between the carb and airbox? Check for other leaks too, just spray carb cleaner around the carb and boots when it's idling. Good luck! Any pics of the ride?
    And, WELCOME!!!!!!!!!!!!!
    My Rags
    NE Arkansas
    2,344
    O, and sometimes the carb kits may have a different brand of jets that could be slightly different in size than the stock one.
    One of my 70's does that after I put a clamp on (open) air filter. I went up a jet size when I did it, just not big enough. I gotta re-jet it.
    My Rags
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Welcome!!!
    Got pics?
    Mar 2008
    florida
    70
    It looks pretty bare sice Im still working on it at the moment. i will post some pics when the project is done though.
    NE Arkansas
    2,344
    You gotta drag El Camino? My uncle used to have a 87 camino drag car, completely streetable, all metal, all throttle, ran 12.30's. Good sleeper car except for the wrinkled ET streets out back.
    My Rags
    Jan 2008
    NW Indiana
    92
    Did you change the plug? What does it look like? Compression test? What is the PSI reading? Does the carb's petcock have the diaphram and was it changed? My cousins long ago had a 70 and it had the same symptoms until we changed the diaphram.
    Bikes I currently own.....
    84' KXT 250
    01' Honda CR500
    98' Arctic cat ZRT800
    82' Honda atc70
    Mar 2008
    florida
    70
    Mine is a 78, first year of the last body style, same et streets too. I have built everything including the trasmission, its killing me that I cant figure out what is wrong with this atc. Its a lawn mower with three wheels for gods sake!
    Columbiaville, MI.
    1,508
    I would take another look at your point's.Your .012 is the minimum gap on your point's,I usually go .016 which is top of spec,and which allow's for wear.When they get to .012 you can see they are wore on an angle,and that's when I pitch the point's.I know you said you installed new point's ,just set them fatt.I have worked on many ,many 70's where I was for sure it was a carb issue an it was almost alway's ,Point's..
    MDR Racing
    LONG LIVE SANCHEZ RACING
    Jan 2005
    Jones, Michigan
    1,821
    Quote Originally Posted by elcamino12sec View Post
    "if it aint broke dont fix it"
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Mar 2007
    Hampshire U.K.
    536
    Is the condenser ok?
    ATC 70, ATC 250es, 1/32 ATC 250R
    1 person in 10 understands binary, the other one doesn't.
    Trikefest UK '08 survivor!
    Mar 2008
    florida
    70
    conderser is new, along with the points, spark plug and everything in the carb.
