1986 ATC 250R left rear wheel wobbles side to side and all around. Everything is tight. Could this be the hub is bad? Do the splines (teeth) on the hubs wear out and that is what makes them bad? Do the bearings fit right behind or inside the hub and could the bearings be bad and not the hub? Can feel the wobble right at the end of axle around hub so its not a bent axle i believe. I would assume that if the bearings were bad that would wear out the hub and vise versa. Better to replace them both if its one of them? Thanks for any help, Bronzeback5.
