ok, well, i got my cylinder back from being ported.......
long story short, it was damaged during return shipping, and the sleeve skirt broke when i was re-assembling it. the piston wouldnt slide back into the cylinder, it was out of round. upon further investigation, it was cracked and/or bent inwards.
SO.
i need a new sleeve for my 300 R, and i need it re-sleeved.
anyone here know where i can get a sleeve?
can anyone here re-sleeve it? how much?
i have the nearly new piston, and would like to use it to save a hundred bucks, so when re-sleeving, can it be worked to use the piston i have? it is on its first bore, so it wont be needed bored halfway out or anything.
and to top it all off, i will have to have it re-ported after it gets sleeved.
and i think the bottom of the sleeve skirt will have to be cut some because it was hitting the crank last time i tried to assemble it. but ill explain that more in detail later.
can anyone help me without breaking my bank? thanks!
