Thread: Chain adjustment (and clip of Jumping 125M)
    tand is offline New to the board Arm chair racerNew to the board
    Feb 2008
    Florida
    12
    Jump clips:
    http://s196.photobucket.com/albums/a...t=CLIP0013.flv
    http://s196.photobucket.com/albums/a...t=CLIP0014.flv
    (The batteries died at the end of the second clip or there would have been more!! )
    So today I went riding and we started out jumping a small bank, then about two miles after that my chain started jumping off the back sprocket. Can I fix the problem like this:
    zoomerman:
    "to tighten the chain there are four bolts holding the axle. you loosen them and them pull the axle back and tighten a little 12mm bolt until it's at the correct tension. then tighten the big 17mm bolts back up"
    Or should I just take links out of the chain?
    BTW: I have an '85 125M
    Thanks
    Aug 2006
    Evansville, IN
    59
    Use the chain tensioner.
    Feb 2008
    Florida
    12
    Quote Originally Posted by redryder View Post
    Ya there isnt a chain tensioner on this model, but thanks.
    Anyone else??
    Aug 2006
    Evansville, IN
    59
    In your first post you talk about tightening a 12 mm nut. That is your chain tensiorer.
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    Theres a chain tensioner, its adjusted by loosening a bolt by the rear brake pedal.
    Feb 2008
    Florida
    12
    Ok thanks that answers my question! I havent been able to get a manual yet.
