Results 1 to 15 of 25
Thread: Atc Starts Then Dies?
    AngusJustice is offline At The Back Of The Pack Arm chair racerFirst time rider
    Canada
    219
    Question Atc Starts Then Dies?
    My 2 stroke starts them dies right away. no idle. wont rev at all. any ideas Thanks!
    Sep 2007
    Nottinghamshire , u.k
    13
    oil's too thick in fuel mixture cloggin up carb ports
    springville, PA
    6,185
    pull your plug and see if its fouled. Probably just needs a new plug if it just started doing this
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Canada
    219
    [QUOTE=norms125m;601839]oil's too thick in fuel mixture cloggin up carb ports[/QUOT Do you mean my oil gas ratio is to rich?
    Apr 2004
    Brigham, Québec, Canada
    1,528
    What is the temperature outside? I think he means the cold weather affect the gas/oil premix and cause this symptoms.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Canada
    219
    its been doing this all summer fall winter it does not seem to matter!
    Canada
    219
    Question
    gas cap off, good fuel flow, carb just rebuilt still a no go!
    Dec 2006
    central in.
    try shutting fuel pet cock off.and drain carb,you should get at least half a carb cleaner cap full of gas.if you do ,have a buddy squirt some premix gas out of an oil can into carb inlet slowly as you start it.wd-40 will work also .I'm betting is a carb problem .float hanging or something plugged.were all passages checked when rebuilt or just a kit? hope this helps Ron.
    Canada
    219
    compression good what about reeds any chance there?
    Canada
    219
    all passages check they said one jet was plugged just put it back on today
    Dec 2006
    central in.
    did you try pulling drain screw to check fuel flow past needle&seat?
    Canada
    219
    please explain undo the bottom of the carb then open throttle to see if i get good fuel flow?
    Canada
    219
    Apr 2006
    Crestview, Florida
    2,429
    Did you check for spark? Try a new spark plug? Does it pop, backfire, bog, ect.. need more info. Did it just die one day or did you buy this way?
    Rides
    85 ATC350X
    85 ATC200X
    Canada
    219
    ran grat when i bought it then started doing this first i would run for only half hour then only 5 min now this and yes it does backfire once in a while!
