Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: Atc Starts Then Dies?
    springville, PA
    6,185
    Quote Originally Posted by AngusJustice View Post
    ran grat when i bought it then started doing this first i would run for only half hour then only 5 min now this and yes it does backfire once in a while!
    but have you tried a new plug yet?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    AngusJustice is offline At The Back Of The Pack Arm chair racerFirst time rider
    Canada
    219
    Not yet what type plug is best ( Or Recommended) for ridding in southwestern ontario canada?
    springville, PA
    6,185
    The one OEM calls for, whats the machine?
    Nate
    R.I.P HRR
    Canada
    219
    1985 honda atc 250R
    Canada
    219
    ok ok I went out tonight when it was dark to check for a spark in the dark and there was a big blue one which was good so I put pre-mix down the sparkplug hole and wouldn't you know it she started right up so this leads me to believe the carb or the reeds are the problem so what do I do rebuild with kit or buy a whole new carb and reed set any suggestions? Thanks A.J.
    Dec 2006
    central in.
    starts then dies
    nothing to do with throttle position.there is usually a drain screw or cap near bottom of carb.first shut off pet cock and check the amount of fuel that comes out .then with drain open ,turn petcock on and observe flow. should be nearly as much as open line was . what trike have you got ?
    Dec 2006
    central in.
    starts then dies
    sorry I've got a slow conn. see you already answered some.I agree it could also be ign. even if you have good spark,I've had 250r's that done simular and just cleaned connections on cdi box wires.I'd still check fuel flow through carb.
    Apr 2006
    Crestview, Florida
    2,429
    if its backfiring, it sounds like a broke flywheel key. I would pull the carb and clean the jets out good, while you have it off look at the reeds for damge and set everything to stock specs. Then with the fuel line unhooked turn on the fuel valve to see if you have good flow. If that doesn't work pull the flywheel and check the key for damage.
    Rides
    85 ATC350X
    85 ATC200X
    Canada
    219
    Well I think I figured it out I pulled The left cover and the Flywheel And The Crank Woodriff key Was Sheared! Thanks For You Help Erics350X I'll Let You Know For Sure Tomorrow When I Pick 1 Up!
    Apr 2006
    Crestview, Florida
    2,429
    Take your old one with you to any auto parts store and have them match one up.
    Rides
    85 ATC350X
    85 ATC200X
