Im looking for a tire that will slide easily under a stock 350x. Are turf tamers by Carlisle any good? Any recomendations?
84 Honda 200ES Big Red
I used turf tamers on my 200x and loved them for handleing. The ground cleaance is reduced obviously and you will have to go up on the front sprocket to make up for the tires in gearing. I just bought a 350x with Holeshots on it. I have not ridden it much yet but from what I can tell I like them to this point.
I just notice that you are in GA. What part? I am up by the Mall of GA
I've had Turf Tamers on everything I've ridden in the woods for the past 15 years (250R's and 350X's) and they've been very good to me. They aren't the greatest mud tire in the world and aren't the most puncture resistant either but they have never let me down. You just need to be a little careful is all. I run 20's on a 9" rim.
John
1985 Eddie Sanders ATC330r
1986 Monstecate
1984 ATC70 (awaiting 125cc transplant)
1984 ATC125M
1986 GSXR 750 - Keepin' it old school!
1999 Arctic Cat 500 4x4 plow machine
1999 Arctic Cat Thundercat 1000 (lake lizard)
1996 Arctic Cat Jag 440 L/C (ditch banger)
Very thin weak sidewall, as long as it's not rocky, they are a good knobby tire. Just like Razr's or Holeshots...........
I just want to be able to kick the rear end out around turns to keep my speed up. I plan to go with 20x11x9s if I can find them.
SCEADU-Im down near Valdosta.
tamers are pretty good tires, like every one said, week sidewalls tho
from what i hear rzx mx's slide rlly good and are cheap. like 50 bucks a tire
Anyone know about these? Is this the one youre talking about? Their Maxxis RZRII.
those look like regular razrs, wich are awsome tires, but a bit heavy, the rzrII's are HEAVY and have a much more agressive tread pattern.
out of the 2 go with regular rzrs
Weak sidewall or not, if you ride with your head you'll have no problems. I've got many years of riding without incident.
John
1986 Monstecate
1984 ATC125M
Carlisle Badlands, they look just like Holeshots
Rides
85 ATC350X
85 ATC200X
I swear by my DUROs...they really do hook up great in a straight line, but the slight twitch of a butt cheek and you can slide that rear end out easily.
just put a set of 20x11x9s on the 350x and have a set of 18s on the 200x.
also...they will go through some mud...the channel in between grips just rips up chunks.
an added bonus...they are cheaper than all hell at rockymountainatv.com
Cmon over to the rocky parts of NewEngland. I'll add your torn sidewalls to the 7 I have stacked up now. Either that or I'll be looking behind for you all day long.....
these are the razor 2s
http://www.tiresunlimited.com/images...Razr2_rear.jpg
my friend had them on his yfz450 and they burned off way to fast
