Thread: Kick Start Problems
    Nov 2007
    Alabama, United States
    9
    Question Kick Start Problems
    Having a problem with the kick starter on my '84 atc 250r
    Sometimes it catches fine, other times it seems like it doesn't catch whatever gear
    it's supposed to catch to turn the engine over. (Its gettin' rough on the ol' ankle!)
    Can this be fixed?
    Terryville,CT
    1,616
    sounds like the same problems as the 200X as where the spring that engages the ratchet gear is worn so it will not put the pressure needed! not sure but its a possibilty ill let the 250R guys chime in for further varification!! but do a search on 200X kick start problems!!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Aug 2007
    Belgium
    86
    I had this on a kx250 dirtbike once, I just sanded the sprockets of the kickstarter a little bit with quite rough sandpaper, that did the job for me.
    Feb 2008
    New York
    23
    my 250sx dose the same it usually is fine but not latly
    Nov 2007
    9
    I've never had a bottom end apart on one of these.
    How complicatded is it?
    Also, my bottom end oil level plug (on the left side cover) has stripped threads, so i'm gonna have to pull that sometime anyway...
