Results 1 to 13 of 13
Thread: rebuild top end?
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    rebuild top end?
    ok, i have a top end on a 2 stroke i need to rebuild.
    i know what all needs to be addressed, i am just not sure in what order to address it.
    i would think:
    Bore cylinder/hone cylinder
    order matching piston kit
    get gasket kit
    re-assemble
    or, would i order a piston kit, then have it bored/honed to the piston kit?
    either way, i cant grind the rings myself, unless someone has a tip on doing so?
    The cylinder has some amazingly horrible gouges and wear marks, i mean absolutely horrible. i cant believe it runs, let alone how well it runs, but it wont last, its piston-slapping.
    i guess, my question would be: should it be ran at a denser oil ratio, like 20:1? its at 32:1, and this damage was done with supposedly low hours.
    Jul 2006
    western ny
    3,366
    if its that bad id get it bored. as long as you know what size bore you want (i would go 2 or 3 sizes up if its that bad) it wouldnt be too bad to order the piston kit and get it over with. i use to and still do order my piston kits threw dennis kirk. they have free shipping and i usually get them in a few days. ive redone many of sled motors and never had any problems. just make sure you know what bore size you want before you go ordering the kit.
    as for grinding your rings ...the kit comes with a paper that tells you how to do it. or it should anyway.
    rebuilding a top end isnt all that bad really. its pretty self explanatory for the most part. a 2 stroke is probably the easiest motor ive ever worked on. no valves no or very little timing to worry about setting..... i love the 2 stroke motor for that reason. i just hate buying the danm 2 stroke oil for the danm things.
    good luck and im sure someone else with more knowledge of the 2 stroke motor (250R?) will chime in.
    GIT IT RAAAGGGGG !!!!
    Danold's Avatar
    Danold is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    barnesville, Ohio
    193
    You should get the piston before you have it bored so they can match the piston to bore. Better than the person boring it to big and ending up with a piston to small.
    85 200x
    85 Tri-z
    86 Bigred
    81 Rm60
    John Deere racing tractor
    Quote Originally Posted by wad
    sorry dude mine are all shitters lol
    Apr 2006
    Crestview, Florida
    2,429
    It prolly wasn't broke-in properly
    Rides
    85 ATC350X
    85 ATC200X
    Feb 2008
    Benson,NC
    56
    I order my pistons first. I then take both to the machinist so he can check the piston to cylinder wall clearance while he has it. Catch is, u gotta know the size u r at b-4 bore so u can order the right plus size piston. My last time dong this i ended up 0.80 over stock, so thats it on this jug. New sleeve next time.......
    I bust-ass on 3 wheels.
    Dec 2007
    Indiana
    235
    Sometimes the problem is the bore is egg shaped...like mine was. Wasnt sure if it was going to true up. I dropped my cylinder off and the mechine shop, told him the stock bore size and what the max bore would be before resleeving, and he called me when her got it done with the new bore. He left enough for honing and so on.
    -Phil
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    ok, thats all i needed to know, weather to buy the piston first or to bore it first.
    so, when i measure the cylinder, i would like to go 2 bore sizes greater, its pretty well beaten up, may have to go three.
    so how many thousandths would each "overbore size" be?
    like, overbore 1 is 10 thou, overbore 2 is 20, and so on.
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    Bump, questions in above post are still unanswered.
    Danold's Avatar
    Nov 2007
    barnesville, Ohio
    193
    Quote Originally Posted by 300rman View Post
    thats correct. I wouldnt bore it out more than you have to so there will be room the bore later.
    85 200x
    85 Tri-z
    86 Bigred
    81 Rm60
    May 2002
    Southeastern Wisconsin
    3,658
    Take it to your machinist and have him mic the cylinder and he'll tell you what size you need. You only need 1 size bigger then your widest spot unless it's right on the edge then 2.
    '02 Honda 416ex - A seasoned blend of 11 herbs and spices
    '04 Honda Recon - The yard machine and snow plow
    '88 Honda CR250R - Another chapter in my torrid all terrain affair
    Oct 2007
    Grosse Tete, LA
    3,440
    most shops give a pretty good discount on a piston when you order it from them and get them to bore it.
    May 2002
    3,658
    Quote Originally Posted by The Goat View Post
    I've never had a shop give me a good price on a piston. Always shop around.
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    i always shop around lol.
    im thinking, just take the cylinder to a shop, and say, i need a piston kit, and need it bored. that way i can take it home and assemble it.
    that bout cover it?
