Thread: 86' 200X carburetor seat, how to remove?
    Merge_88 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    St. Louis area
    262
    Today, I was trying to remove the seat for the needle in my carburetor and can't figure out how in the heck it comes out. Is the seat just pressed into housing or will it unscrew? I'm confused and don't want to mess it up, please help! Thanks!
    1983 Honda 70
    1983 Honda 200
    1986 Honda "Super" 200X
    1983 Honda 250R
    1985 Honda 250R
    1985 Honda Big Red
    1986 Honda 350X/400EX conversion
    2005 Yamaha WR450F conversion
    1985 Yamaha Tri-Zinger
    1986 Kawasaki Tecate
    The lower brass seat that the needle rides in is underneath the main jet. Take the bowl off and use a small blunt nosed punch to punch it out from the top side. It should come out REAL easy or you will damage the seat....It is barely a press fit. More like a small interference fit.
    Nov 2007
    St. Louis area
    262
    Hummm, I'm talking about the needle/seat that controls the fuel coming into the bowl. You are talking about the needle that the throttle cable is connected to correct? Maybe I'm confused but I think we are talking about two different seats.
    The problem I have had with the carb is that once the petcock on the tank is turned on, fuel pours out of the overflow on the bowl of the carb. This has led me to believe that the needle/seat needs to be changed. Correct?
    Thanks
    1983 Honda 70
    1983 Honda 200
    1983 Honda 250R
    1985 Honda 250R
    1985 Honda Big Red
    Ahhhh, OK....
    No, I don't believe that seat is available and it's pressed in well. More than likely the rubber tip of the needle that connects to the float is just old and hard..... (edit- lol, people won't understand)
    Anyhow, get a rebuild kit, flush the tank, clean the petcock and have at it!!
    Nov 2007
    St. Louis area
    262
    Ok, i'll give it a shot! Thanks!
    1983 Honda 70
    1983 Honda 200
    1983 Honda 250R
    1985 Honda 250R
    1985 Honda Big Red
