a 125m is a 4 stroke. DO NOT MIX OIL WITH THE FUEL. only put oil in the crankcase. the plug is probably fouling because your mixing oil with the gas. when your not mixing oil with the gas, it could be fouling because its running too rich, you probably need to adjust the carb and lean it out. im not sure what oil to use for the crankcase, but someone else will chime in. have fun, be careful 3-wheelers are addicting.
My Rides
1983 ATC200 - U-Haul edition - great mudder - SOLD
1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
1987 Suzuki DR200
199? Go-ped Sport
