Results 1 to 7 of 7
Thread: Some quick ATC 110 questions, Answer quick!
    JTM is offline First Time Rider Arm chair racerNew to the board
    Oct 2006
    Connecticut
    79
    Hi,
    I know I'll probably get harassed etc. but what oil should I put in my 83 110 and where is the drain bolt for the oil etc.? Also my muffler is half missing, I will probably weld it, but What should I do until then, it'll just be real loud right?
    -JTM
    [Blue]1983 Honda ATC 110
    1985 Honda ATC 350x Fixer
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    5-W30.........
    The oil drain plug is on the bottom of the motor.
    Oct 2006
    Connecticut
    79
    Thanks, That's what I thought but I wanna make sure that I do everything right. It's been a while since it's been run etc.
    Oct 2006
    Connecticut
    79
    Just read up on the pdf manual, Why does it say it takes SAE certified 20w-40 or 20w-50 just wondering? and do they still make that? What's the difference?
    Thanks,
    JTM
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    They are for different temps in the seasons.You can find any of those oils at a Walmart for dirt cheap.
    Oct 2006
    Connecticut
    79
    So that means 5w-30 is year round? I shouldn't have problems right? Thanks bro
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Quote Originally Posted by JTM View Post
    Yes...........ride it for a while,then drain it rite after.This will get out all the crap in there.
