Results 1 to 15 of 23
Thread: pit marks in dome of cylinder head
    Jan 2005
    Slatington PA
    4,372
    Can this be wet sanded smooth again (pits are pretty deep) or should I just look (probably?) for a good head that isn't pitted at all ?
    This is off a MX bike but the question I'm sure would pertain to any 2 stroke head dome.
    What exactly does this effect when running a machine like this ?
    My theory is they created hot spots which in turn make the bike run leaner then it should be, am I way off in my thinking, does it do otherwise ?
    I wouldn't worry about running it myself. But, if it bugs ya I'd just get it machined, cleaned up and resurfaced.
    Not sure if yamahondaman is still around, he never answered my PM's.
    Dec 2005
    Wisconsin
    1,141
    Sand it down and run it. Had a zr500 that ate 3 pistons and the rings beat the head up bad. Bought a new head the first time. Second time we sanded the dome down and ran it. Sold that hunk of junk lemon of a snowmobile. I wouldn't be afraid of using it is you sand it down.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    the pits wont hurt anything.
    sanding the pits down will make the dome larger, and could cause a substantial drop in compression.
    put it together and run it.
    Terryville,CT
    1,616
    use a dremel and you can polish them out carefully not taking away to much material to make it smooth again! and of course check to see if its flat on a peice of glass or something of that nature!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by 300rman View Post
    1st you say it may cause a substaintial drop in compression (I knew that is a possibility), which if it does, I'm certainly not going to put it together and run it.
    You make no sense ?
    Using a dremel is not the best idea, one slip and you damage the sealing area. Run it or machine it is the best advice I can give ya
    You would have to sand or grind the HELL out of it to lose compression.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by tri-Z ripper View Post
    That's an idea! I will ask my engine builder guy too though, see what he says about all these comments.
    Jan 2005
    Slatington PA
    4,372
    The dome area can just be machined ? What type of machine does it?
    a milling machine,,,make shure you show him this..
    or this
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    Quote Originally Posted by Huffa View Post
    You make no sense ?
    how dont i make sense?
    i said the pits wont hurt anything.
    i said sanding them out could cause a substantial drop in compression.
    i said you would be fine to put it together and run it with the pits.
    what didnt make sense?
    Sep 2005
    Lipetsk, Russia
    2,824
    I've seen heads like that all the time, rebuilding snowmobile engines here in Nome. There's a theory that rough surfaces on the head help turbulate the fuel-air mixture and result in a cleaner, more complete burn. I don't know if it's true but I've never noticed a large drop in performance running a used head like that.
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    if its a two stroke, its fine and a lil normal. run it, a machined head wont do any better...if lil at all.
    Jan 2005
    Slatington PA
    4,372
    NO, you didn't say it in that order ......
    " the pits wont hurt anything.
    put it together and run it. "
    The way you phrase it above, it's to be taken as put it together and run it even though I could have a sustantial drop in compression. The " put it together and run it " should have been in the same sentence with " the pits wont hurt anything."
