Thread: How to remove Z water pump seal?
    Hanston, Kansas
    126
    Man I am stumped! I have been tinkering with this thing for a couple hours. Whats the easiest and simplest way to remove this sucker? Any help would be mucho appreciated
    drew
    lol.. stick a screw driver in between the two seals in the center and work it around in a circle..prying down...little lube around the outside.. there tough..even I fight them
    Hanston, Kansas
    126
    Much appreciated raffa! I looked through previous threads but no one gave a good idea how to do it, so I thought I would ask.
    Thanks again,
    Drew
    Sep 2007
    oregon
    2,292
    I'd find a crap screw driver and use a grinder to give it an egde, that worked real easily...
    Mar 2005
    ma
    988
    becarefull installing the new one. they go in tight and i screwed up my first one i installed.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    yes you are correct .. make shure you lube the hole and the seal.. find a socket the perfectly fits on the hole .. and use that to tap it In.. dont hit it hard or you will knock the spring off the lip inside the seal.. then your all done ..I have spent 5 hours trying to get that spring back on the lip ..and I'm gonna tell you this .. its impossible!
