couple questions on 200x rear shock rebuild
Finally tore it apart and from what I can tell the only problem was it was low on oil because of a leaking shaft seal. I went ahead and drained and refilled it with ATF and did what the book said to reassemble but I got just a little bit of air trapped in the system still since there is no way of bleeding the air out. It seems to work fine so I guess it won't hurt anything? To recharge the reservoir I just used compressed air at 225 psi. Yes I know the book says 298 psi of nitrogen but air works too. I guess my question is what is the nitrogen charge for? I couldn't see that it did a heck of a lot since the shock worked fine without it but I went ahead and put 225 psi or air in it anyway. Last, the adjuster wheel on the bottom I'm assuming is to set the rebound rate right? I played with it and it seemed to me like it did change the rate but it may have just been me seeing things.
1984 200X bored .040 over, mild port work, K&N filter
Planning on custom exhaust, XR200 carb and cam
