help and tips plz
im leaking oil on my 82 atc200 i think its leaking around the shaft behind the sprocket how hard is this seal to fix what needs to be done?
ok i was looking at it and cleaning off some oil/grease build up and it seems to be leaking at the shifter shaft seal any help would be nice thnx
you should be able to buy a new seal and pop out the old one with a screwdriver and tap the new one in with a socket.
ok so thats all ther is to it pop it out and push the new one in? thnx for your help im gonna order one today
//ArrowChat Integreation Code
