Thread: NGK spark plug question
    Feb 2008
    NE Indiana
    525
    I goofed the threads on my 85 YTM225 the other day. The stock plug is a NGK D7EA. The thread diameter is 12mm. Is there any reason why I couldn't drill it out and tap it for 14mm and use a B7ES plug, which is 14mm thread? I believe you can swap a D7EA or a D7ES, so why couldn't I just run a little bit bigger thread diameter. It's almost the perfect save. If that one gets goofed, then I'll need another head. By the way, there's room by the valves, so I shouldn't have to worry about the seats. Any thoughts? I can fixture it up on a knee mill to get it true & round, and power tap it straight thru. I love working at a machine shop.
    smvorndran
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by smvorndran View Post
    smvorndran
    Why not just install an insert and get it back to stock?
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    yeah, if it gets boogered up again, any machine shop can fix it no problem.
    Feb 2008
    NE Indiana
    525
    My Honda dealer's going to throw a Helicoil in it for me tomorrow for $10. Problem solved! Thanks.
    smvorndran
