Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: 350x clutch slipping after 5 days?
    Hampton, Virginia, C.S.A.
    2,664
    I haven't ever had any bad luck with a BARNETT clutch and soaking them in plain 10W40 oil for about a half hour. I've installed at least 4 Barnett clutch kits in a 350X, 200X, 250R (OEM set) and an XR200 come to my immediate mind. The same procedure was used every time.
    I WOULD NOT buy an EBAY clutch kit unless it was either genuine OEM or Barnett.
    What brand of plates and springs did you purchase??
    pro racer kit off ebay and now its is slipping once again after i switched the plates around...im stumped on what the problem is becuase the same thing happend....i was fine fir about 4 days and in the blink of an eye it started slipping so bad it wouldnt hardly move wtf?
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    You really do get what you pay for. As far as EBAY goes - I don't mess with chains and sprockets, brakes, clutches,etc etc and I'm still scared to buy one of the "new" brake calipers they have on there. Some of the deals are so cheap that they have to be junk.....
    2,664
    could anyone give me a list of cause of why the new clutch would slip after 5 days so i can do the process of elimination...that would be great
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Charles Town, WV
    1,316
    Most likely sub standard quality parts.
    I think I may have chimed in on this discussion before. I used Vesrah fibers and hate them, AND that is known brand name. If you went with an ebay no-name set, I'm sure they are the cause of all your problems.
    Buy OEM fibers, reuse steels if they aren't blued or cracked, get new springs (if you haven't already), adjust it correctly and be done with it.
