Results 1 to 10 of 10
Thread: Clear coating on bare metal......?
    piroguedog's Avatar
    piroguedog is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    South Louisiana
    302
    I was wondering about this in reference to aluminum and steel. What is the difference in doing this and painting it? I have sanded the rust off of a steel wheel and have it smooth and shiney I like the finish but am not sure how clear coat would work compared to priming and painting. Also, i have been sanding the motor on a trike, top and bottom ends and also like the finish. So, anyone have any experience with this??? Piroguedog
    1985 ATC 250SX
    1982 TRI-MOTO175
    1986 ATC 200s
    NY
    3,185
    Ive done it with parts I didnt want to paint and it has held up fine on riders and show machines
    piroguedog's Avatar
    Nov 2007
    South Louisiana
    302
    Orange, any recommended clear coat, and have you done steel as well as aluminum? Thanks for the 2cents.
    1985 ATC 250SX
    1982 TRI-MOTO175
    1986 ATC 200s
    NY
    3,185
    I have not done aluminum just steel....it is neat look. No particular brand.
    evand is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2007
    MA
    523
    i did it to the head for the z. i used the VHT high heat clear, wich i would recomend if your doing this to a engine. it came out very nice and shinny, i have done this to steel and had good results
    Lancaster, PA
    1,738
    I have cleared polished alumiuim, just clean the piece with some type of degreaser/brake clean to remove any wax.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Oct 2005
    saratoga, ny
    2,819
    i sprayed my polished metal parts after a good cleaning and it came out nice. keeps em looking good for along time.
    piroguedog's Avatar
    Nov 2007
    South Louisiana
    302
    Well, I opted to prime and paint the front rim, but am still going for the polished alum for the motor. I was afraid that the coat would get scratched too easy on the wheel and then rust.
    1985 ATC 250SX
    1982 TRI-MOTO175
    1986 ATC 200s
    Utah
    644
    Bare metal will rust, for my axle (metal, steel, whatever) I polish it up and then put a coat of clear coat over the top to keep it from rusting. All my other metal parts I paint with primer and paint.
    Aluminum will pit and dull. It wont rust like the metal, but over time it pits. I guess it ok bare and exposed. I wonder if you can affectively clear coat aluminum to help protect it??
    Edit-Re-read your post, I misundertood the first time. My guess would be painting would be more durable, because then you could use a good quality primer to help protect the metal as well. But then again clear coats do a good job at protecting the paint.... so to put the clearcoat on the metal itself... Like I stated above, I put the clear coat on my axle, its better than nothin.
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
    Feb 2005
    Orchard Colorado
    659
    I've done powder over bare aluminum and bare steel. It gets blasted first so it’s clean. After blasting NO degreasers or other cleaners, right to the powder coaters. It is the best finish and most durable. It doesn't scratch or flake like paint. I'd do powder over a or high quality mix and spray any day.
    If you like the look of the aluminum make sure that the clear doesn't yellow with time or exposure to UV. I have a set of triples that I cleared with Formula U (it's a RC air plane paint) that is resistant to nitro methane. It yellowed after a couple of years. Now I wish I had gotten them powder coated "aluminum".
    Just make sure to have it done by someone that's good and NOT CHEAP. If you go cheap you'll have a cheap paint job that doesn't come off.
    '85 Cagiva 200
    '86 Cagiva 500
    '82 ATC 480R
    '83 ATC 250R DG
    '83 Nicholson 185s
    Owned 5 Franks, sold 4, have one left.
