Ok guy's I need some carb help. I have a ytm-200 and am working on getting the adjustments right. I know I could go to the book and adjust accordingly and it should run fine... That is if I was running gas. My project here is to get this thing running on E85. I went up to a 140 main jet. I was running a 102.5 with gas. According to everything I have read you need to jet up 35% when running E85. The thing runs good on the top end, I just have a mid range problem and a little idle issue to work out. When I rev it up it takes a few extra seconds to wind down to idle. Is this a lean or rich problem? Which way should I go with jetting, or should I change the needle clip placement?
I'm trying to get it to run on E85 as is stock to see if I can get it to run how I would like as is. If it works out I will rebuild with a hi comp piston; you can run more compression with E85 as it is compared to about a 100 octane fuel.
Thanks guy's!
