Thread: 200s Clutch slips
    BigRed_Ryno is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Kent UK
    311
    200s Clutch slips
    After rebuilding te top end of my 200s, ive taken it out for a test run, only to find that anything more than half throttle, the cluch starts to slip. Now, when i had the engine in pieces the clutch plates were all fine, i was wandering if this could have been caused by using the wrong type of oil (10w 40 part synthetic motorcycle oil)
    or by flushing it with diesel when i rebuilt it? any thoughts would be greatly apreciated
    Tionesta, PA
    5,747
    I have heard that synthetic oil will make the semi-automatics slip some. I would change oil and run plain old 10W40 (30)
    Jan 2008
    Kent UK
    311
    so do you reckon just changing the oil will do or to change the clutch plates now they're contaminated with synthetic oil?
    Aug 2006
    Evansville, IN
    59
    Try using some 10w30 with an API rating of SEor SF.
    Jan 2008
    Kent UK
    311
    I'll give it a whirl
