Results 1 to 11 of 11
Thread: Another bent axle....2days = 2 bent axles
    ct
    1,396
    this time on my 85 250r,
    Anybody want them, probably 1/4 in wobble. I have 1 for an 86 250r and 1 for an 85 250r.... $25 for both +shipping
    any way toreally straighten that works??
    Apr 2007
    Springfield, PA
    889
    i know someone that had a bent 200x axle, and they heated it up and had it pressed and it came out straight. idk maybe this helps?
    My Rides
    1983 ATC200 - U-Haul edition - great mudder - SOLD
    1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
    1987 Suzuki DR200
    199? Go-ped Sport
    Nov 2006
    southern oregon
    2,338
    it can easily be straightened out in a press... 1/4" is nothing..
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    My X had a bent axle, I just replaced it, because I was told by others that when you straighten them, they get weak, one hard jump they could snap, just my .02
    TF 07,08,09,10,11,12,13,14!
    ct
    1,396
    I just swapped it out...Thank god for Red bull!!!!
    ready to ride tom!!
    Apr 2006
    oakridge oregon
    124
    What ever you do don't heat it up . Just straighten it in a press, you can put it in a lathe and check it with a dial indicator .
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    my cousin bent his big red axle. the local shop straightened it no prob.
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by moose 53 View Post
    X2, you don't want heat!
    Apr 2006
    PA
    1,464
    Yes dont heat it up, that would weaken it. It sounds stupid but when my axle was bent I didnt have access to a press so I put a couple small washers on 2 of the wheel studs to counter the wobbling, suprisingly it actually worked.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,243
    hell rex and i put his in the reciever on the back of someones truck,, with a cheater pipe and a few good jumps on it it was within an 1/8 of an inch!!! good to go!!! lets ride,,,,,,,,
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    i like this guy!
