The bolt holes for the cam sprocket themselves should be at 12 o clock.
In other words, at TDC on the compression stroke the cam lobes should be AWAY from the rocker arms by 180 degrees. Both rocker arms should have play in them at this point. This also helps set the ignition timing as it should be firing at this point or you have it 180 degrees off.
Ignition timing being off is nothing, just won't run. But cam timing can bend a valve if it is off. Best to double and triple check it and then run it over smooth with the plug out to be sure until you understand it.
