Results 1 to 7 of 7
Thread: why no fire
    Oct 2007
    alberat
    32
    why no fire
    i have a 185 i pull and pull and pull and no fire. I have changed the spark plugs and nothing. I have checked to make sure the timimg is correct and is, the compression is 117 psi and when i put fuel down the spark plug hole and pull over still the same nothing. Seems like it doesnt even want to fire.. Today i changed the ignition coil with another and nothing now i am stumped. Any help would be muchly appreciated , one other thing i checked to see if both valves were moving and they seem not to be sticking.
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    Im in the same boat as you, I had my 200e running, now it wont start with; compression/timing/spark.
    Yours might need more compression, like 120-150
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    make sure you have spark. hold the plug against the head and have someone else pull the rope while you look to see if it is making a spark.
    sounds like a spark problem, as fuel in the cylinder doesnt even let it pop.
    also, maybe the valve timing is 180 degrees off?
    and 117lbs compression seems real weak to me.
    Mar 2008
    SoCalifas
    74
    check the ground wires on the coil pack and make sure your get spark>gl
    Sep 2006
    S.E. LA
    700
    Does the compression release work? I have a 200s I'm working on and it won't start unless the lever is down (valve closed).
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    Oct 2007
    alberat
    32
    decompression lever
    yes decompresiion lever is down and it seems to workand to pull over when lever is down and easy to pull when lever is up.
    Sep 2006
    S.E. LA
    700
    Yeah thats the way its supposed to work. The easiest way to check spark is to use a volt/ohm meter and check voltage at the plug wire. See if you get a reading every time you pull start it (should be around 12v-14v). If you do then you know your getting spark. If you don't have a meter then hold the plug against the motor while someone else pulls the starter. You should see a nice blue spark.
    Also, make sure your on/off switch is working correctly and check the GROUND WIRE where its connected to the frame.
    '04 EZGO TXT
    Former trikes;
