Carb issues on a 82 185
I have an 82 185 without a service manual. It runs ruff at low rpms but better at high rpms. I cleaned carb, but can not put together because my bowl gasket in not in yet. I checked the compession, 150. If you hold the spark plug against the motor and she sparks. So I have to think that the problem is in the carb. I guess when I assemble the carb it will be yea or nay. Does anyone no what the carb mixture screw adjustment is? Any feedback will greatly appreciated. Thanks
try 3/4 turn out...if that dont work just keep turning it till it idles smooth
According to Clmyer it is 2 turns out.
Thanks for the settings gentleman. If this is not the problem, has anyone had any problems with intermiten spark? Hopefully it is the carb.
//ArrowChat Integreation Code
