Most 2 strokes do need a case splitter. Some guys put the long bolts back in a few turns and lightly tap them evenly all the way around as a chinsey method of case splitting.
I've split plenty of cases and I don't have a tool for all of them so I make my own. A piece of flay bar 1/2 thick x 1.5" wide and you drill and tap a 1/2 - 13 hole in the center. Then drill 2 other holes that line up with some threads on the left case behind where the stator was mounted. Then you just need a piece of 1/2 - 13 threaded rod as the "pusher" that presses the crank away, and a couple of bolts to hold the bar into the case holes. Last one I made needed 2 long studs so I welded 2 8mm x 1.25 bolts together, threaded them in the case, slid the bar over them and put a nut on top. I think that was for a Blaster.
It can be made for nothing if you have taps, drills and metal kicking around or just a few bucks if you have to source them.
Hope that made sense......
