Results 1 to 8 of 8
Thread: 200X exhaust interchange?
    az
    2,018
    theres a 200s exhaust on ebay. Its advertised as a 200X pipe too. Does anyone know if they interchange? Ive got a 84 X and curious if this would work? thanks jim
    Apr 2006
    PA
    1,464
    Dosent look like it will work, the mid section of the pipe isnt bent like the 200x, so it may not clear the frame.
    Nov 2007
    Southern Oregon
    108
    Don't forget the 200s is a center mount tailpipe
    STEALTHDUNER
    Trikes I Own
    1983 ATC300R (Stealthy)
    1986 ATC250R (ESR310)Twin))
    1986 ATC250R (Stocker)
    1985 ATC200X (Racer X)
    1985 ATC350X (Thumper)
    1984 ALT50
    1986 TRX250R (ESR310 PV)
    1988 TRX250R
    1997 Yamaha Banshee
    2004 TRX450R
    Sep 2006
    S.E. LA
    700
    The header from a 250es is the same shape as a 200s but unfortunately doesn't look like it would fit right at the head.
    I'm pretty sure the exhaust from a 200e is the same shape as the 200x, but I'm not 100% sure.
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    oldred95 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2006
    OK
    196
    I've got (well my dad has it but doesn't even know what it is) a Bassani 185/200S muffler thats in good shape. I experimented with it on my 200X and without chopping it up there's just no way it would ever fit. Its too long and the angles are all wrong.
    1984 200X bored .040 over, mild port work, K&N filter
    Planning on custom exhaust, XR200 carb and cam
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    190
    I came across this ancient thread while searching… I found a very minty 200x muffler locally, and I was wondering if it would fit the 350x head pipe? Seller thinks “they’re the same” and I know the baffle inside interchanges but it’s not cheap so I don’t want to buy it if it won’t fit. I don’t want to cut it up if that can be avoided.
    Feb 2017
    Corona CA
    858
    Quote Originally Posted by J!m View Post
    No. The only thing that swaps is the rear grab bars.
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    190
    Thank you, Shawn.
