Thread: T3 forks----are 85 & 86 interchangeable?
    Sep 2006
    Shreveport, Louisiana
    888
    And what would be the benefit, if any, to running 86 forks in my 85 triples?
    Thanks,
    Chris
    >>>>>>>>>>>>>>>2007 Yamaha Raptor 700R>>>Cross Country Racer<<<<<<<<<<<<<<
    www.myspace.com/bluelionracing
    Support my 2009 sponsor:
    For all your ATV suspension needs.
    Nov 2006
    southern oregon
    2,338
    I doubt the '85 tripples can safely be bored that far.. 36 vs. 41mm...
    Mar 2008
    Tug Hill
    1,282
    well i got two chassis' let me go measure them and ill get back to ya...when i got all the parts there was a front fender from a red tecate so one of the frames might be older
    Oct 2005
    saratoga, ny
    2,819
    fork tubes are of different sizes. 38mm on the 85 as upposed to 41mm on the 86. not sure if the 85 triples will work even being bored out. and you would have to change grind off and change the steering stop if you were to swap triples. but thats still easier then boring them out.
    Back in Happy Valley
    833
    Scooterroo can the 86 triples be bolts right on to an 85 frame aside from the steering stops? Also Is anyone running honda fork tubes/hub/wheel and brakes on the front of a T3?
    I have a lead on a liquid R chassis and the front end is complete on it, would that work in an 86 triple tree? I can make spacers for the hub/brakes without any issue if one it different from the other...
    Mar 2008
    Tug Hill
    1,282
    just checked all of mine are 41mm...figures
