Results 1 to 15 of 16
Thread: xr200 transmission in a 200x?
    Jun 2007
    Canton, SD
    93
    will the tranmission gears from a xr200 fit in the 200x bottom end im have trouble finding a xr200 bottom end
    My ride 1985 200x
    oldred95 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2006
    OK
    196
    I'm waiting for Jenn over on .org to reply to my PM so confirm that it is a direct gear swap.
    If all you are after is the gears which really is about the only thing usable from the XR200 bottom end, then it may be just as easy to get them from honda if you still can.
    1984 200X bored .040 over, mild port work, K&N filter
    Planning on custom exhaust, XR200 carb and cam
    Jun 2007
    Canton, SD
    93
    well all i want is a six speed so i was just wondering if i can just use the gears from the xr
    My ride 1985 200x
    Feb 2006
    EC
    1,607
    Do a search,there's plenty to read about the xr swap on these boards, but I'm pretty sure you've gotta use the xr bottom end w/xr cases. Good Luck.....
    Baltimore---Charm City, or Harm City? Ask Pat.....
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by the great gazoo View Post
    Really? I have never done this swap but I have read a lot about it. I believe the 200x cases work fine, but you need just about everything else in between. You need both XR gearsets, shift drum/forks/shaft. The kicker assembly needs the XR gears but the X shaft needs to be swapped over.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Last I knew you just used all the XR shifting mechanism and gears/shafts and guts
    JENN knows, where is she
    JENN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I KNOW she has posted about it before so start searching if in that much of a hurry.......
    Dec 2006
    OK
    196
    I couldn't find anything deffinitive on .org about the conversion. What I found was her thread questioning it and what all is involved but at the end of the thread I knew no more then when I started, just a bunch of mixed opinions from the members.
    Seems to me like gears, shift drum and fork(s) and possibly the lever should do it.
    Aug 2007
    Brookings, South Dakota
    133
    Hey Tyler if you get that XR engine I got dibs on your old one for my XL125.
    '81 ATC 250r: IMS tank,Uni pod filter,Keihin PJ flat 38mm,Boyesen Pro series reeds,reed spacer w/ boost bottle,milled head,bored(.080),ported,machined CR exhaust flange,and Mugen pipe.PK +3 swingarm,2+2 axle,ITP rims,and 200X fork swap w/ polished tree.
    '03 CR 250R: FMF fatty w/shorty, Pro Taper top clamp
    '85 ATC 70: 88kit, race cam, ported head, 5 angle valve job, cobra pipe, 20mm carb...
    '73 ATC 70 roller, '80 ATC 110, '86 ATC 125m, '81 XL 500s, '71 Z50, '76 Z50 W/ Lifan 125
    '84 Tecate 3
    Jun 2007
    Canton, SD
    93
    ya that lady backed out she made up something about ebay policies so she is putting it on there
    My ride 1985 200x
    Aug 2007
    133
    well bid on it. I'd love to have your engine. I got that carb tuned perfect.
    '84 Tecate 3
    Jun 2007
    Canton, SD
    93
    ya im going to try she hasnt put it on there yet she said she will let me know
    My ride 1985 200x
    Apr 2007
    Springfield, PA
    889
    yes, so what all would you need to drop a xr200 6-speed into a 200x bottom end?
    also, are the 1,2,3,4,5 gears on the xr200 the same ratio as the 200X, and 6th gear just ads more top end? is a xr200 geared lower then the 200x? or is the 200X geared lower then the xr200? thanks.
    heres the other tread on this: (xr200 trans swap starts at 1/2 of page 1) http://3wheelerworldforums.com/showthread.php?t=81968
    My Rides
    1983 ATC200 - U-Haul edition - great mudder - SOLD
    1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
    1987 Suzuki DR200
    199? Go-ped Sport
    Dec 2006
    OK
    196
    It looks like there are two ways of going about the swap. If you are fortunate enough to find a good XR200 engine here is what is the best option to do. Swap the 200X kicker and side cover onto the XR engine and use that. But its not quite that simple. You still have to split the case on the XR to put the 200X kicker in it because part of the kicker mechanism is on the inside of the case. The cases of both engines are identical, only the parts that are put inside them, and the kicker and cover are different.
    To put the XR200 gears into a 200X case you must split the case and transfer over all transmission components into the 200X case. There are only a couple reasons why you would want to go this route vs the first route. Your donor engine has a bad crank or some other issue like mine does. Or you are a stickler to detail and want to keep the stock engine case for the numbers, and just because you like to keep things original to an extent.
    I personally am going to swap the XR gears into my 200X case.
    Jan 2005
    Tennessee
    850
    Get in touch with 200x Basket. I believe he did this swap if I remember correctly. It has been several years.
    Dec 2006
    OK
    196
    Quote Originally Posted by hancadam View Post
    I am and I have. Been posting on .org and thats pretty well what was decided. You either put the 200X kicker in the XR engine and run it which requires splitting the case or you put the XR gears in the 200X which requires splitting the case. Either way your gonna be splitting the case.
