is a 29mm carb too big
Finally measured the carb I'm getting off the XR200 and its a mikuni that measures 29mm. I know that is not the stock XR carb but it seems to run ok other then a little bit of a dead spot around 1/3 throttle. I did some searching and the stock XR carb is 26mm and the general idea is that is plenty of carb for a 200X with the typical mods. Is the 29mm really going to be that much of a difference? It ran reasonably well on the XR but the crank locked up and its getting parted out so now I've got the carb to toy with. Opinions?
1984 200X bored .040 over, mild port work, K&N filter
Planning on custom exhaust, XR200 carb and cam
