Page 2 of 9 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 133
Thread: Tiger200: its got a freind now.
    There are NO current Tiger action shots. They don't get used, they just get looked at.......
    yes there is.. erector dale.....He rides His! me and him at TF 06
    and thats before he fliped it on the drag strip and shatterd them rear fenders!
    NY
    3,185
    looks like a very respectable start!!!!!!
    Aug 2004
    Cedar City, Utah
    474
    Thanks for the kind words guys. I havent ridden it yet, needs some clutch work, not sure whats wrong yet. If anyone can PM me that has been into one of these id be grateful. Im betting its something simple. It fires right up in one or two kicks every time, no waterpump leaks either. Sounds great too!
    As far as action shots go, i'll see what I feel like doing when I get it going, and dont expect to see any fenders on it (these are not perfect, but I intend to keep whats left of them intact.)
    Thanks for all of the valuable info on your website OC, you can add this one to the 250 count if you would like. Things I noticed with this one are that the steering neck isnt stepped like all of the others on your page, and it has Kayaba Front Forks instead of Marzocchis, they look like they are original to the bike as well. just an FYI. Thanks again! HH
    NY
    3,185
    Glad you like the site...I have plenty of updates unfortunetly I am just a little to busy at the moment to complete that....I only have one tiger in MY collection with the step up stem....the rest are like yours....they are a slightly earlier model with the step up. looks like the rear of your fenders are trimmed....if you do a search I have fixed that problem on two sets of my rear fenders. Savor that shroud....dont break it!!!
    Mar 2008
    SoCalifas
    74
    NO action shoots??????whats the point ownnig a monster of a trike.! i guest just ownnig one is the thrilling part>i wont one.
    85 250R
    85 ATC 70
    iowarotax's Avatar
    iowarotax is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2006
    iowa
    393
    If it has not been ridden in awhile, the Rotax clutch will temp lock up. Put in 2nd or 3rd gear and roll it back and forth a few times. Also the adjuster in the center of the clutch cover, needs to be screwed in untill it touches and then backed off 1/4 to 1/2 turn. There should be a way to lock and unlock the set screw. If you need some tips on the clutch adjustment go to the Classic Can-Am site and search around a little. Good info and a couple sources for engine parts.http://www.atkmotorsports.com/atkbb/...ght=406+clutch Hopefully this link will work. It guides you through adjusting the clutch.
    198? 250 Tiger 198? 200 Tiger 198? Tiger 500 1985 KTM 500 1985 Can-Am mx-lc 250 1988 ATK406
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    This should be a good trike for me.I should get one.
    It could be.
    Your actually very similar, you shine it all up for weeks, stuff it in front of a mountain or lake and consider yourself an ATC rider.......
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    It could be.
    I'm really getting sick of you chit azz wipe.
    Aug 2004
    Cedar City, Utah
    474
    progress pics
    got a little bit done. pics of an intake I made for it, polished up axle, and some other things as well. rebuilt the carb too
    Attached Thumbnails Attached Thumbnails Tigerintake.jpg   Tigeraxle.jpg   Jemco.jpg   JSilencer.jpg   36Mikuni.jpg
    good job harry..keep at it .. intake looks killer!
    Aug 2002
    691
    Awesome bike Harry! A rare find for sure. When is the alky conversion going to happeN? hahaha
    73 cr250m elsinore, 85 atc70, 85 250r flattracker, 87 250es bigred, 86 tecate, 2004 gas gas de300
    Aug 2004
    Cedar City, Utah
    474
    Shock is restored!
    just a little update... been super busy at work and just getting little things done on the tiger here and there. got the front hub all pretty with new paint, and wheelbearings. and FINALLY got the resivoir back for the rear shock. sent it off 4 months ago! Figured I would share the results and ask if anyone knows what the recommended Nitrogen PSI would be for this shock?
    the bypass hose was shot so I had this one made and used swivel fittings on it and a 45 at the shock so I can run the line a little better. (old one got a hole poked in it from the stud on the seat pan, now that wont happen again.)
    Attached Thumbnails Attached Thumbnails YSParts 045.jpg   YSParts 046.jpg   YSParts 047.jpg   YSParts 048.jpg
    bad350's Avatar
    bad350 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    kentucky
    176
    Awesome Looking Trike!! I've Always Wondered, Are Parts Hard To Get For Those Do They Still Make Parts For Them?
  15. #30
    Sep 2006
    Northwest Indiana
    1,893
    Now that's a beautiful shock!!!! Can't wait to see the progress pics of the whole bike.
