Thread: fuel tank leaks
    Oct 2007
    alberat
    32
    fuel tank leaks
    has anyone tired to remove rust from a fuel tank. I was wonder the best method for doing this. Any and all help please would be greatly appreciated.
    Sep 2005
    FL
    855
    I use muriatic acid. You will need to seal it up after your done. There also a lot of products made for cleaning tanks.
    "In a society that tries to standardize thinking, individuality is not highly prized." -
    -- Alex grey
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Dennis Kirk has some stuff called Kreem that works good. On a teenage budget I've used diesel fuel and put nuts and bolts in the tank and shake it.
    TF 07,08,09,10,11,12,13,14!
    darrel632 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    alberta
    429
    use clr, or phosphoric acid, recoat with redkote we talked about this, you have a nice trike the simplest fix for the thing is to get a clark plastic tank. 100 bucks and your good to go.
