Thread: tri z banshee axle
    Mar 2008
    Tallahassee Florida
    9
    tri z banshee axle
    if i am using an aftermarket banshee axle in my 85 tri z carrier can i use the sprocket/brake hubs from the tri z or do i have to use banshee hubs? if i were to use a banshee brake hub and disc can i use the tri z caliper? or how can i make it work
    85 Tri Z
    Aug 2005
    Lockport, NY
    2,395
    sprocket hub will work. As well as the brake hub. You may need to space the caliper over. I am not sure if the banshee rotor is the same diameter as the tri-z. It may need to be turned down on a lathe in order to make it work.
    everything will work but the brake hub and rotor..there wider and the rotor is bigger..use the tri z hub and rotor
    Mar 2008
    Tallahassee Florida
    9
    if anyone has any of those parts for sale including the tri z carrier let me know thanks
    85 Tri Z
