Results 16 to 30 of 33
Thread: Is there an alternative for expensive Filter oil??
    I'm gonna see how well WD40 traps the dirt particles. It would certainly be cheaper, cleaner and easier to apply...
    Jul 2006
    western ny
    3,366
    hell yea it is, ive used it and the "air cleaner oil" and i like the wd allot better.
    GIT IT RAAAGGGGG !!!!
    May 2002
    Southeastern Wisconsin
    3,658
    I can't believe that some people still use wd-40 to protect ANYTHING on an offroad machine.
    '02 Honda 416ex - A seasoned blend of 11 herbs and spices
    '04 Honda Recon - The yard machine and snow plow
    '88 Honda CR250R - Another chapter in my torrid all terrain affair
    Quote Originally Posted by OldSchoolin86 View Post
    This topic was brought up to see if anyone of you guys had anything else that could be used as an alternative to air filter oil.
    It didn't mean that I'd never use filter oil again, it was merely a question.
    WD40 works great at removing moisture from wiring and ignition systems, it's also always worked decent for cable lube in a pinch, and it may work well in trapping dust particles in an air filter. I'm not sure yet and I haven't tried it out.
    WD40 also helps remove dirty and contaminated nuts and bolts and helps things slide together that are dry and stubborn.
    Yes folks, WD40 may in fact still be useful in the offroad industry. But thats not up to me, I'm not an expert..........
    May 2002
    3,658
    You said it best when you mentioned "in a pinch".
    Feb 2003
    California
    623
    Use SAE 80 or 90 GEAR oil. Don't use too much or it will restrict air flow.
    Aug 2002
    691
    This has to be one of the dumbest threads ever. It isn't like a airfilter has to be done everytime you ride, how much did you pay for your bike? Unless it was free or a complete beater , then what is 6 or 7 bucks to protect your motor and not have to fool with rebuilding it? If a alternative oil is used, I would use regular motor oil, but it isn't going to work as well, and wd40 is definately not going to cut it. Just by testing to see if it traps dirt or whatever, you put yourself at risk of putting wear and tear on your motor. You can't fill up a 3 wheeler tank with gas anymore for the amount you are discussing, nor buy even a quart of good 2 stroke oil etc. If a bottle of filter oil is too high this isn't a hobby for you haha.
    73 cr250m elsinore, 85 atc70, 85 250r flattracker, 87 250es bigred, 86 tecate, 2004 gas gas de300
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Quote Originally Posted by 86waterpumper View Post
    Hey mister I-know-everything I got a couple of question for you. You seems to know everything about filter oil.
    What is so special about filter oil?
    Sure the company that sell you the bottler wrote on it that it is specially formulated to increase the filter life and decreased engine wear, but can you say what is the exact formulation of that oil?
    Where are the fact about filter oil?
    They may sell you loose nut or WD-40 in a different bottle and you won't know.
    I remember reading my Honda user manual and they say to clean the filter in solvant and oil it with regular engine oil. Don't you think HOnda know it better than you.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    May 2002
    3,658
    LMAO! Well said pumper.
    I'm not sure why I'm gonna waste my time on this but I will....
    What part of "IS THERE A" don't you fools understand??
    Are you stupid? or is it just today? or is it a full moon?
    None of you clowns who do not have or cannot recommend an alternative need reply. The topic will merely go away on it's own....
    It's a question, like this one "is there an alternative to Yamabond?" - Answer "yes, there are numerous manufacturers of liquid gasket which will work just as well"'.
    I've got plenty of money for filter oil, just wondered if anyone used anything else that was either less expensive or performed better.
    For all I knew, someone who has raced and wrenched for years has found out that PAM spray or Bees wax works great and even better than air filter oil
    May 2002
    3,658
    Maybe you're new to the internet........... but when you make a thread you may get different opinions and input.
    Mar 2005
    overton, PA
    5,257
    you need a tacky or sticky liquid that will catch the dirtand dust i have always used a grease arounfd the rink and a white lithium grease in an arosol can and squeezed it into the filter and then a littel w'd to thin it out slightlybut thats just my .002 cents
    Again, with your stupidity........
    Anyone who advised against anything other that filter oil could have said, "I wouldn't risk using anything other the the right stuff....."
    But apparently you had to raise your feathers like a cock, oops, I meant to say peacock
    Quote Originally Posted by brapp View Post
    Lithium grease is pretty dam sticky, just like filter oil. Thanks Brapp, I may give it a whirl.....
    May 2002
    3,658
    Dude, this isn't your back yard, it's the internet. If you post something dumb chances are people will call you on it. I mean you're really delusional if you think you have the right to the perfect internet conversation. My actions in your precious thread are not about trying to look like the alpha dog, it's about how stupid and cheap people can be. I mean seriously, you started out by bitching how much filter oil is. Boo hoo, either you need a better job or like Pumper said you need a new hobby. I'm still blown away that people would use WD-40 on a filter! My sympathy really goes out to anyone that can't instantly tell a difference between WD-40 and filter oil.
  15. #30
    Marion, Ohio
    622
    this actually is helpful cause ive always bought the K&N recharge kits and they do get a bit pricey, but i dont know if i have the nads to try something else haha
    I got nothing...
