Thread: CDI- Teacate vs Kx?
    Mar 2008
    Stockholm/Sweden
    64
    Question CDI- Teacate vs Kx?
    Does anybody know if the CDI unit from a Kx 250 will fit the `86 Tecate
    *1985 Yamaha Tri-z 360 big bore Ohlins with powervalves, 38-carb, boyesen reeds and pro-circuit exhaust!
    *1985 Honda ATC 350x "stock"
    *1981 Yamaha Tri-moto 175 "stock"
    *1982 Yamaha rz350 with Jolly-moto exhaust
    *2004 Kawasaki sixdirtysix Stuntbike
    *1987 Pontiac Trans-Am
    *1996 Pick-Up
    Jul 2006
    Depends on what year kx your talking about. If you do use it you will also need to use the stator and flywheel from the same year kx.
    Mar 2008
    Stockholm/Sweden
    64
    Ok..
    The previous owner have replaced the hole ignition with kx parts, and now the stator is broken, but not the CDI
    so if I go and order a Rickystator for "Tecate" from E-bay, it won`t work with the KX CDI that is installed on the trike!?!
    *1996 Pick-Up
    Jul 2006
    Better ask them first or see if you can replace the parts that are damaged with oem.
    Mar 2008
    Stockholm/Sweden
    64
    OK I`l try that, Thanxs!!
    *1996 Pick-Up
