The gas filter on my 85 atc70 has some orange stuff in it, and im wondering how I can clean th inside of the gas tank?
 First Time Rider
						Arm chair racerNew to the board
						First Time Rider
One of those electric paint can shakers might come in handy...just a thought...
use swimming pool acid it works great will make trailprotrailpro tank like new make sure that u nurtualize the acid with baking soda tho also make sure that you just have the acid touch the tank and nothing elce it will eat it up hold on let me go find out what the actual name of the acid is its murtaic acid
I've heard also a good thing you can do is get some gravel, rinse it well to get the dust off of it, fill the tank about 1/2 full of gravel and poor in wd40. then again shake vigorously and repeat as necessary.
1986 Tecate
1984 Tecate
1985 Tri-Z
1986 ATC350X
1985 ATC250R (2)
1985 ATC125M (2)
1982 ATC70 - Original Owner
175 TriMoto Frame with Pro-Tec Rear Suspension
3-Wheelin' since '82
 At The Back Of The Pack
						Arm chair racerAt the back of the pack
						What I like to do is get some big ball bearings, or rocks or nuts, etc. And dump in a little Muratic Acid and shake it around thouroughly and rinse it out and you can follow that up with some naval jelly. Or you can just use naval jely for the whole process, then rinse it thouroughly and blow everything out with an air compressor.
ATC350X,ATC70,1991 RM 250,XR500,TM400,TS400,Foreman400 4X4,Polaris 425 Magnum,ATC 90, 1982 175,1973 Honda Trail 90,1980 CR80,1981 CR80,
Yes I have a very very rusty tank, actually, 2. I was also wondering how u get that rust out.
The muratic acid one, I've herd of that before. But how much? and should you dilute it with water?????? The ball bearings and stuff in there sound pretty good too.
1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
when i did it i use about 9 oz and slushed it aound then pored it out i didnt delute it any and it burnt my skin also
 First Time Rider
						First Time Rider
						I went to Kmart and bought a big box of bbs and dropped them into the tank with some mineral spirits and shook the cr@p out of it for about a half hour and then rinsed the tank out good and made sure all of the bbs were out worked great for me
Happy Trails
						Naval jelly is a rust remover, and it kind of stops rust to. It is like paint stripper but for rust. It is pretty god stuff.
 First Time Rider
						First Time Rider
						WHAT R MINERAL SPIRITS?
looking for a 250r for sale in the bay area
Mineral spirits R paint thinner ! :-P
Trike's owned over the year's:
1983 Honda 70.............Purchased Used
1983 Honda Big Red......Purchased Brand New
1984 Honda Big Red......Purchased Brand New
1984 Honda 200s..........Purchased Brand New
1985 Honda 200s..........Purchased Used
1985 Honda 200X..........Purchased Used (Still Have)
 First Time Rider
						First Time Rider
						Does anyone know where I can get Naval Jelly?
Ask for it at any hardware store.
 First Time Rider
						First Time Rider
						Okay so im thinking about pouring naval jelly into the tank with some screws and shaking it, does that sound good?
