Iv rebuilt the carb the i dropped the needle was on 3rd notch now on the top one "im not sure of the correct name for it the one that works with the main jet" adjusted the screw on the front of the carb which i think it supposed to make it run lean or rich with no prevale it sux having to change the plug every time i ride i cant seem to figure it out ne ideaswould be gladly excepted
Thoughts
exause is shitty has some holes in it and the spark aresor is floating around in it
air cleaner is not new but is not that bad looking
replaced choke plunger
put new jets in it aside from the main but it was a stock rebuild kit
could a coil become weak and not have a hot enough spark or are they just eaither working or dead?
