Results 1 to 15 of 20
Thread: how to get snapped stud out of cylinder
    joe_f7's Avatar
    joe_f7 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2008
    SE wisconsin
    227
    Angry how to get snapped stud out of cylinder
    took all my studs out of my case and cylinder. all came out fine except one in my cylinder and it snapped off. any tricks to getting it out? can i helicoil it?
    1986 Kawasaki KXT 250 tecate
    ported, FMF pipe, DG silencer, boysen stage II reeds, 39mm keihin PWK, T4 thumb throttle and front master
    Jun 2003
    Anchorage/Homer, Alaska
    480
    If any of the stud is sticking out you might be able to vise-grip it and remove it.
    If it is below the surface, and your very good with a welder, you could weld just a small ball to the top of the stud. Keep welding balls (stacking) till you have enough to put a vise grip on. This has worked for me before on a 125m engine.
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Mar 2008
    Tug Hill
    1,282
    if its sticking out some tighten a nut on it and weld it from the top then you can turn it out with a wrench
    joe_f7's Avatar
    Mar 2008
    SE wisconsin
    227
    nothing is sticking out
    Aug 2005
    Lockport, NY
    2,395
    Unless you have a clue. Take it to a machine shop and have it done. Otherwise you will be sorry after you trash it. IMO
    joe_f7's Avatar
    Mar 2008
    SE wisconsin
    227
    just seeing if anyone has had some success with a helicoil. used them many times before just not with a snapped stud.
    Sep 2006
    Northwest Indiana
    1,893
    Helicoils do work for some people. I prefer using time-serts. A little more involved to get them perfect, but they are the best solution to your problem.
    joe_f7's Avatar
    Mar 2008
    SE wisconsin
    227
    never heard of them. i'll have to google it.
    Jul 2006
    iowa
    451
    sometimes you can set a nut on top of the broken off stud and then fill the inside of the nut with weld, welding it to the stud. the weld will only stick to the steel nut and stud, and not the aluminum cylinder. Make sure you wait for it to cool down so it contracts, and if your lucky it will back out with a wrench.
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    get a screw extractor, like 2-5 bucks at a hardware place
    joe_f7's Avatar
    Mar 2008
    SE wisconsin
    227
    kind of worried about snapping off a screw extractor in the stud since the stud snapped off
    Sep 2005
    Missouri
    469
    Quote Originally Posted by hondahaulic View Post
    It you hit the broken stud with a and punch, it might loosen or release the binding presure of the stud in the aluminum. Then ...... You might also want to place a thick and large diameter washer over it so you can weld it better, then weld the nut on the inside and outside to the washer. Like hondahaulic says, let it contract. After the cylinder is back to room temp, then I ussaully heat up the aluminum with a torch(try not to heat the stud) around the stud and then try turning it. Aluminum will expand faster than steel, just dont melt the aluminum.
    Nov 2006
    southern oregon
    2,338
    I used 3 heli-coils for the head studs of my LT with no issues... even with much higher compression than stock... But I would try to avoid them if possible... I would definately try to weld a nut onto the stud and work the stud loose... use some heat and some good penetrant... work the stud back and forth.... it may take awhile... it may require welding on multiple nuts..
    Mar 2008
    Merced, Ca
    44
    get some left handed drill bits (sounds funny but im serious) and drill the stud. with those bits the drill runs in reverse and when you drill down so far it can sometimes grab the stud and back it out. works pretty good. soak it first with pb blaster.
    Nov 2007
    Southern Oregon
    108
    I had this exact problem with two studs. Do yourself a favor and have a machine shop do it, I had a screw extractor break off in mine and my machine shop wouldn't touch it (hardened material) I ended up finding another machine shop that had a an ultrasonic vibrator that got it out, then they installed two Heli-coils and they installed all 6 brand new honda studs so it would be fresh and I havent had any problems.
    OH and some machine shops will charge you a REALLY high hourly rate (mine was $85 an hour) until they get a broken stud and screw extractor out. They quoted me a minimum of 2-3 hours. In my case i would have bought a new cylinder
    STEALTHDUNER
    Trikes I Own
    1983 ATC300R (Stealthy)
    1986 ATC250R (ESR310)Twin))
    1986 ATC250R (Stocker)
    1985 ATC200X (Racer X)
    1985 ATC350X (Thumper)
    1984 ALT50
    1986 TRX250R (ESR310 PV)
    1988 TRX250R
    1997 Yamaha Banshee
    2004 TRX450R
