Thread: Clogged gas cap
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Clogged gas cap
    I have a gas cap that is the same as a big red gas cap that is stuck. Its not allowing for enough air to get into the tank. You have to have the cap half way and drive slow to keep up with the little air that gets in.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Ryan. is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Michigan
    317
    spray some carb cleaner in there
    1997 Yamaha YZ250
    1985 Honda ATC350X
    1989 Honda XR100R
    Quote Originally Posted by SWIGIN View Post
    a wise old racer told me years ago you just hold it wide open till you see god.......then shift
    Mar 2005
    overton, PA
    5,257
    or you can use a torch cleanign tip to clean the vents in the cap also.
    Nov 2002
    1,838
    So the cap is reusable? Thats great. I thought I would have to throw it out.
    What "sticks" on these caps? Is it the on and off switch or the actual mechanism?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
