Results 1 to 8 of 8
Thread: burning through oil (84 200x)
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    My friends 200x just got new oil and after riding around we found it was almost less than half! At first we let it idle then tried went up on the clip, still the same. Whats going on? Also his is running HOT, the exhaust got hot enough to boil water after 10min of idling, yet the plug comes out a dark tan?
    Apr 2006
    Crestview, Florida
    2,429
    You need to let it set a minute or to after running before you check the oil. That gives it time to drain down. Unless its smoking, then its time for a topend rebuild.
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2006
    Seattle
    1,552
    Alright I went out and quickly checked his bike, its back down to normal. But what about the heat? Should I take a pic of the plug?
    It was running fine until we changed the oil.
    Oct 2007
    Grosse Tete, LA
    3,441
    what weight oil did you put in it?
    I never run less than 20w50...but it's really hot down here in louisiana.
    Nov 2006
    Seattle
    1,552
    Thats what he used 20w50
    pull the rocker cap off and start it ,see if the oil is reaching the top..a easy check.
    Nov 2006
    Seattle
    1,552
    too late now, i will tommorow. thanks, didnt think of that
    Apr 2006
    Crestview, Florida
    2,429
    Its prolly fine, 4 stroke pipes get pretty dang hot.
    Rides
    85 ATC350X
    85 ATC200X
