Results 1 to 3 of 3
Thread: 1982 200 clutch
    Mar 2008
    Ontario Canada
    10
    1982 200 clutch
    just wondering if anyone out there can quickly tell me the proper procedure for adjusting the clutch on my 200. It started acting wierd a while ago, but whats happening is well, imagine driving a standard car without useing the clutch. Igoes into first gear from neutral fine, then when the engine is reved up it WILL NOT shift into second untill the rpms come down then its fine into third fourth and fifth but a bugger to get back into neatral from first. Any help would be great. Thanks
    Nov 2002
    Kirkville, NY
    3,831
    Welcome to 3 Wheeler World Eskort.
    There is an adjuster on the right side engine case (clutch cover). Loosen the nut (I think it is a 14mm) then turn the inter screw counter clockwise until you feel a little resistance, then turn clockwise 1/4 turn and tighten the nut (hold the inter screw from turning).
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Mar 2008
    Ontario Canada
    10
    thanks for the welcome. And thanks for the tip, i wasnt sure if it was counterclockwise or clockwise, its been a long while.
