Thread: 250SX miss above 4200 RPM
    Jun 2007
    chula vista ca
    Hello:
    I am new to this forum, and I do not have a three wheeler. What I do have is a 1985 Honda 250 SX engine installed in an off-road go kart. The engine is running well at low rpm, but has a severe miss starting about 4200 rpm. I have replaced the coil and sparkplug wire which has corrected a miss from idle to 4200 rpm. My question is, does this ignition have a rev limiter? My second question is, does anyone know what the redline is?
    Thanks for the help
    springville, PA
    6,185
    Quote Originally Posted by lynn View Post
    Hello:
    Thanks for the help
    yes it has a rev limiter but 4200rpm is only like 1/2 way. The 350x is 9000rpm so i believe the SX is 8400rpm or so. If you have a miss from 1/2 throttle up most likely its a fuel issue. Are you running a stock carb? whats the setup?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jun 2007
    chula vista ca
    Thanks for the Information. The carburetor is stock, however I have not looked inside yet. So I do not know what the Jets or needle position is. I will check the fuel situation and let you know what I find. The miss is not exactly half throttle, I can punch to full throttle and kart accelerates without hesitation or a miss up to 4200RPM
    Sep 2008
    Winnipeg,Manitoba,Canada
    86
    check the fuel/air mixture screw but be careful ajusting it to far one way or the other, usual setting is 2 1/2 turns. (never tighten screw all the way because it can put a groove in the needle) to get the setting turn screw in untill lightly seated then count turns out to 2 1/2
    that is what i think of non 3-wheelers
