350X Problem..........
I need some help figuring this one out.......
When my 350 gets warm to hot it will not shift for crap and finding neutral is almost impossible. This has been getting worse since I bought it a year ago. I installed a new clutch last fall and a new pressure plate. Upon inspection i noticed the basket had some grooves worn in it so i filed as much as i dared out and installed the new clutch. I believe this is not allowing the plates to float properly causing the plates to drag just enough to make it shift poorly. Any help would be appreciated.........
85 350X, 85 250SX, 84 200X, 72 US90
