Results 1 to 8 of 8
Thread: TRX250r and 250r
    Dec 2007
    521
    TRX250r and 250r
    do pretty much all trx250r parts bolts on a 250r except for the fronts ends?
    A Rental Car is the only true all-terrain vehicle.
    " I actually think it is good that you have clubs where people can go and enjoy riding these things together. It reminds me of how the prisoners on death row have fun waiting for their turn on the electric chair. Fair enough, the trike isn't an electric chair, but it is about as safe and comfortable as one."
    http://www.nps.gov/bicy/
    Sep 2003
    Elizabethtown PA
    1,581
    the only major parts that work are the motor related stuff and all the rear end stuff and brake parts minus the master cylinder.
    86 atc and 86-87 trx rear end stuff is the same
    i know i mite get hung for saying this if you have a trx250r frame ,complete front end and plastic and seat stuff. you can rape a 86 atc 250r to make a trx quad
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Dec 2007
    521
    so the rear shock, swingarm, axle and related are all the same?
    eddie pettengil is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    nh
    297
    yes, if you use a trx shock make sure you get the linkage for that set up. the bottom bolt are different size. also you will need to space with washers the top bolt because the atc shock mount is wider (use the atc bolt there as the trx bolt is shorter). swingarm, axle and related are all the same.
    Jun 2003
    englishtown NJ
    2,676
    actually, 86 atc250r's used the bigger bottom linkege bolt too. Also, 87's used the shorter dog bone linkege pieces.
    Feb 2007
    nh
    297
    my 86 trx bottom shock bolt was thinner than my 86 atc bottom bolt. had to use the whole trx linkage and trx shock to get it to work. I have heard others say they used the atc linkage with a trx shock and had no problems. This is just what i found on mine.
    Nov 2006
    Florida
    1,663
    Quote Originally Posted by deathman53 View Post
    I'm pretty sure the 88-89 use the different linkage setup
    SCEADU's Avatar
    SCEADU is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Atlanta, GA
    330
    I have hear the shock is shorter on the 88-89?
