Thread: Skidoo motor in trike
    Tilton Newfoundland
    612
    Question Skidoo motor in trike
    Last night i took the motor out of a trashed bravo and lodged it in place in my 200m roller..the motor fit good with lots of clearance for the motor and carb.. i was wondering about the clutch and saw a centrifugal clutch at a industrial parts stor. They have the correct size for the shaft off the motor and everything else I would need . It would slide on in place of the primary clutch on the motor. The clutch is used oftenon a go kart or a simmalar thing . When it engages it engauges on a 12 tooth sprocket that is the same the front sprocket on a trike. and with the right motor mount the chain will allign with the rear sprocket. This would be a project for the fun of it. Anyone wanna add to this or make any suggestions would be great.
    1998 F150 reg cab
    Elan Ski-doo resto mod
    2012 Brute force 650
    98 ranger street truck project
    All my rigs are Loud and proud
    http://bikepics.com/members/mitchell-gosse/
    Mar 2008
    Tug Hill
    1,282
    my brother built a 200x with a 340 liquid rotax engine and i put a 500 twin on a blaster but both had primary and secondary clutches with a jackshaft and a sprocket on the jackshaft going to the rear sprocket.... im intrested about a centrifugal clutch that fits a snowmobile engine! that makes it much simpler
    Jul 2006
    iowa
    451
    The centrifugal clutch will definately make it a much simpler setup. I put a john deer 340 in a 225dx and the clutches and jackshaft setup was probably the hardest part. The only thing i would be woried about is not having any kind of variable speed, your clutch will either be engaged or not engaged (or slipping and burning up). As long as the sled motor has a wide rpm range it should still work.
    Tilton Newfoundland
    612
    It should be simpler but im not totally sure if it will work but its worth a try. If it does it should be a whole lot eaiser to use sled motors in trike. If it dont work im still gonna try to put the secondary clutch in there but i hope the centrifugal clutch will work. Its gonna be a couple of weeks till i get the clutch and any amount of progress besides motor mounts but i'll get pics then.
    1998 F150 reg cab
    Tilton Newfoundland
    612
    hondaholic. I was wonder if you could post a few pics of your 340dx. in case of the centrifugal clutch not working i want to use a secondary clutch and when i go to your thread of the 340 the pics dont work. Theyd help alot. thanks
    1998 F150 reg cab
