http://sandiego.craigslist.org/nsd/mcy/652182148.html
not mine and i have no idea where it is but check it out!
13:1 piston....?
Jeez why downgrade to a 22mm carb!? thats like the size of a 110 carb, stock is 24. Some reason im doubting that it has a 13.whatever piston.
1986 200x- old school D.I.D wheels, Gold D.I.D X-Ring Chain, Rad MFG. Carrier, PRM Grab Bar, Pro Circuit T-4 custom, Maier plastics, 85x forks, 18x10.5x8 kenda klaw mxr's on itp steels, the money pit never ends![]()
they used 13:1 pistons back them, the 22mm carb doesn't make any sence to me, I beleive curtis sparks sold a 28mm carb. I doubt that sparks rebuilt that motor either recently, maybe 10+ years ago he did. Didn't curtis sparks also use dual plug heads too? It does look like somekind of oil cooler is on it.
dennis kirk used to sell curtis sparks 13-1 piston kits back in the day....so they are real
the carb must be a miss print...could be a 32mm
TC did the dual plug head thing...and more, he did some with 3 or 4 but but they were weak (cracked between all the holes)
WWW.HREATV.COM
the Tc racing 200x i had was a 13 to 1 compression piston with a 32mm electron carb. the engine was in a 88 trx250r chassis. the guy did it after they outlawed trike racing
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
is that a westcoast swingarm on there...looks kinda white?
I want those rear fenders.
Not a bad looking bike, if it has what he says then it probably moves pretty good too.
