Results 1 to 15 of 22
Thread: Worlds straightest Laeger T-pin 250R steering stem.
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Ryan. is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Michigan
    317
    pretty straight if you ask me! haha
    1997 Yamaha YZ250
    1985 Honda ATC350X
    1989 Honda XR100R
    Quote Originally Posted by SWIGIN View Post
    a wise old racer told me years ago you just hold it wide open till you see god.......then shift
    hey bill check with aaron , I bet he has a strait used one.. he bought a Laeger flattracker and parted it out.
    Ontario, CANADA
    4,538
    holy piss lol thats bout as straight as micheal jackson
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    PA
    3,515
    lol...they get worse then that
    WWW.HREATV.COM
    Live Oak, FL
    15,069
    My dad worked on it and got it straightened out a lot, not perfect but tons and tons better then it was. I think I'm gonna go ahead and run it. To be honest, I couldn't even tell it was bent before, the front end always felt a little twitchy but I figured that was because of the toe. Shows how much I know about quads
    Feb 2008
    Michigan
    317
    i never knew you had a quad billy, so you have a 250r?
    1997 Yamaha YZ250
    1985 Honda ATC350X
    1989 Honda XR100R
    PA
    3,515
    yeah run it ......it will be fine
    WWW.HREATV.COM
    Live Oak, FL
    15,069
    Yeah I have 2 actualy. an 87 R that was mint when I got it, my first quad I ever owned I got circa 2000 I think it was? And then I got this old beat up Laeger retired pro bike last year for $3500+ the cost of getting it here. Seemed like a good deal at the time but I'm beginning to wonder cause ITS BEAT.
    Live Oak, FL
    15,069
    http://3wheelerworldforums.com/showthread.php?t=71329 Theres the thread of when I got it.
    Sep 2003
    Elizabethtown PA
    1,581
    $3500 is a deal no matter whats wrong with it. it was about a $14,000 or more quad to biuld it from scratch.
    id like to ride it one day to see how much different it is from my 86trx250r. i have standard width front end and suspension with PEP's all the way around
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Live Oak, FL
    15,069
    Any ideas on what might be bent to cause the left front wheel to have about 3/4 of an inch more camber then the right when they are both adjusted evenly? I had to use almost a full nut width to get the thing to straighten out where they were both close to being the same.
    PA
    3,515
    thats normal for aftermarket bikes
    just ajust it out with the king pins
    WWW.HREATV.COM
    Live Oak, FL
    15,069
    I did, its just that now I've got about half a nut holding the spindle to the top A-arm. I guess its gonna be OK, I jam tightened it up so I don't think its going anywhere but still al ittle bit spooky.
    I've got an electrical problem now or something on it, cranks up and idles pretty good at low rpm but backfiring and popping around when you try and get into it.
    PA
    3,515
    on my bike i had to shorten the peice the lower ball joint goes into on the right a arm just to get that side closer.
    dont forget back in the mid to late 90s is when we ran super camber...lol
    and alot of a arms from back then have a ton of camber built into them (upper arms to short) mine are the same way.
    thats why you might want to shorten the lower to help
    WWW.HREATV.COM
