Results 1 to 9 of 9
Thread: How to tension a chain on a 86-87 200x?
    Dec 2007
    521
    i want to remove tension from the chain on a 86 200x anyone know how?
    A Rental Car is the only true all-terrain vehicle.
    " I actually think it is good that you have clubs where people can go and enjoy riding these things together. It reminds me of how the prisoners on death row have fun waiting for their turn on the electric chair. Fair enough, the trike isn't an electric chair, but it is about as safe and comfortable as one."
    http://www.nps.gov/bicy/
    Loosen the 2 pinch bolts, rotate the carrier in the desired direction. Most of them are not maintained and they are seized up, hence the reason so many of them are beat to chit.
    Dec 2007
    521
    the the bolts in the center back of the swing arm?
    WLL's Avatar
    WLL is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    pa
    317
    Quote Originally Posted by bigpimpin View Post
    yeah thats right
    [B][I][U][SIZE="5"] TURN THE SWITCH ON DUMMY!!! thada boy.
    click here and drag edog is gay over here [B][I][U][SIZE="6"]
    Dec 2007
    521
    ok then the carrier is just suppose to rotate?
    Kentucky
    2,294
    Yes, but don't forget to loosen the one in the middle towards the bottom of the carrier. Most people forget to do this and that's why the all end up getting beat to hell.
    Dec 2007
    521
    ok cool. thanks
    Not true about the bottom bolt.
    The bottom bolt (if it installed properly) is just a stop. It has nothing to do with the carrier rotating for chain adjustment.
    If you hit the stop and the chain is still loose, it's time for a new chain and or sprockets.......
    Kentucky
    2,294
    True, if it's still the factory bolt. I've seen alot of people that have lost the original and replaced it with one that was a little longer. If that's the case you'll need to loosen it. Either way, good luck with your chain.
