Results 1 to 15 of 18
Thread: what special tools do i need to replace valves?
    Dec 2002
    salem, nh
    1,339
    i'm doing my first top end rebuild on an 85 atc 110. What do I need to replace valves and grind the head for them to fit?
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Aug 2004
    Ab Canada
    4,368
    Take it to a machine shop, you wont be able to aquire the tools to do it proper, valve grinder, Seat grinder, Lappin stick and some compound, and of course the spring decompressor.
    1985 Tri-Z-
    Jul 2006
    western ny
    3,366
    i did valves on a 90....never again am i going to do them...never ever again. they give you no room to work. but i did get them in.
    GIT IT RAAAGGGGG !!!!
    Dec 2002
    salem, nh
    1,339
    wow really? i didn't think it was THAT hard.
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    PA
    3,515
    90's ans 110's are the worse to do..... as long as you have a spring compresser you can get them in and out
    WWW.HREATV.COM
    This is where the confusion comes in. Honda says not to grind the valves which I would assume that lapping would remove whatever coating is on there also.
    I took my 250SX head to my Huge Honda dealer and he cleaned it up, put new valve seals in, said the guides were good and charged me 150$.
    I asked "why didn't they get lapped? there are hours on this motor" and they insisted they never touch valves. Sounds F'd up to me....
    It's just so hard to find a good reputable machine/motor shop that is reasonable.....
    I did assemble a 200X head with a huge c clamp and a piece of pipe cut away for the keepers to slide in, it worked but the correct tool would certainly be sweet....
    PA
    3,515
    i always lap honda valves with no problems down the road
    i think they were feeding you a line of BS
    anyone know the trick of useing a cordless drill to lap valves? i use a cordless drill since they normaly spin slower but put the drill on low and insert the valve in the head with laping compound on the head and put the valve stem in the drill and lap away.
    i go in one direction for a few seconds and then go to reverse....this also will make any bend in the valve easy to spot
    just be 100% sure not to get any lapping compound on the stem since it will chew up the quide
    WWW.HREATV.COM
    Dec 2002
    salem, nh
    1,339
    Quote Originally Posted by My trike Sucks View Post
    sooo, why cant i acquire those tools?
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Feb 2008
    NE Indiana
    525
    Valve spring compressor & a lapping tool with compound. Most of the heads I've done just needed lapped. A few had worn out valves, but not very many. I got my valve spring compressor at Sears. Lapping tool at Advance Auto or Autozone.
    smvorndran
    Dec 2002
    salem, nh
    1,339
    i'm not even sure it needs valves. i bought it with no compression. pulled the head and saw it was on the stock piston. bought 2 sizes over just to be safe and figured i'd do the valves as well. maybe i wont.
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Jul 2006
    western ny
    3,366
    lol a word to the wise.....on a smaller honda (90 and 110) dont do them unless you have to do them.
    Aug 2004
    Ab Canada
    4,368
    i just did a 70 head yesterday with no problems,,,just need a magnet and a pick to get the keepers in, you can lap them yourself, See where there cutting, see what they look like, but they probably need the seats re-cut, to do it properly, Easy trick to tell, Lap em, and see if you can see any light though the ports,,,if there is, there done.
    1985 Tri-Z-
    Hampton, Virginia, C.S.A.
    2,664
    i did the valve job with great success on my 350x...i didnt even use a compressor just some elbow grease and compressed them by hand...have a friend remove and install the keepers...and i lapped mine with no problem
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Dec 2002
    salem, nh
    1,339
    i had a C clamp with a ball end that compressed the springs no problem. i think i made a small mark on the end of the intake valve with the C clamp end however, not sure if it's a big deal or not. I couldn't believe how easy it was though. How should I go about cleaning up the head and valves? wire brush and carb cleaner?
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Make shure you clean out the valve guide.
